MNTOC Wiki Posted September 4, 2019 Share Posted September 4, 2019 Version 2019.32.1 Software Update The status bar will now indicate when there is a software update available to be download. Tapping the icon will take you directly to Controls > Software for additional details regarding the update. Wheel Configuration If you have purchased new wheels or are swapping them for changing weather conditions, you can now update your car's wheel configuration. After you have completed changing wheels, tap Controls > Service > Wheel Configuration and select the appropriate configuration setting. Note: Changing your wheel configuration will impact your car's estimation of range, tire pressure warning levels, and the car visualization New Language Support You can now select Norwegian as your language. To update your language setting. tap Controls > Display and select the desired option from the Language drop down menu. This release contains minor improvements and bug fixes. View full page Quote Link to comment Share on other sites More sharing options...
